Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
Sort of. You will need to modify or replace the throttle cable bracket on the injector pump. There are brackets out there. I think Kennedy Diesel still carries them. Also you will might have a clearance problem with the rad hose going around the alt.
You can use the OEM hose from the civ truck that uses the dual thermostat. The one I had rubbed a bit. IIRC the heater hoes and bypass hose threads were both 1/2NPT. But a reducing bushing from the hardware store will get it done.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
