Ok, but that isn't as the manufacturer intendedWell, my speedmeter is corrected for the larger tires with the appropriate adapter (on the transfer case).
![Wink ;-) ;-)](https://www.steelsoldiers.com/images/smilies/icon_wink.gif)
It makes no sense to compare your modified situation to a stock deuce.
-Chuck
I am not an expert on the MF injection system in any way shape or form. I hope to be before I am done, but who is to say when that will be?Amen stumps! Lol so any thoughts why I can't get this thing over 2100? My throttle rod from the pedal to the ip arm has a smooth curve in it but i believe that isn't an issue. When you depress the pedal you can feel and hear the point where that spring on the rod starts depressing and then there is probably another 1.5 inches of travel past that point. So I'm under the assumption it's getting full throttle. However, is it possible for the return spring to pull against that governor spring and not let the arm travel all the way to a full position?
As well it should be. These trucks are rated to run 11.00x20's (singles or duals is not the issue). Check your data plate. The appropriate adapter is correct by the manufacturers standard.Well, my speedmeter is corrected for the larger tires with the appropriate adapter (on the transfer case).
Thank you! I can't help but notice that the cross reference listing you provided doesn't include the M44 series in the listing for the lower ratio gear. An oversight no doubt.Here you go stumps, all standard parts...
You can favor it if you like, but they are not the same diameter.I kind of favor the idea that 11x20 and 9x20 NDT tires are the same diameter.
Ok. As I said earlier, I have not measured them, so I can't know either way. They could have made the 9x20's and 11x20's the same diameter if they wanted to by a slight change in the profile.You can favor it if you like, but they are not the same diameter.![]()
I couldn't say, the truck is really new to me. It was getting about 7.4MPG for the 1200 mile trip home with its K-Mart M109 shelter on the back, and about 3000lbs of payload. Most of the trip was between 45 and 50MPH as measured by my GPS. On level ground I could get it up to 55MPH, but hills brought it right down. I think the grade that brought it down to 35 was 5%. It was marked on the turnpike with a warning sign.stumps, if your truck drops that much speed on a 5% hill, your fuel rate must be set very condervative. and yes the 11:00 tires are larger, they are just by chance almost exactly the same as 14.5R20 which is very convenient.
tom
Welcome to SS, now respect your elders young man!I couldn't say, the truck is really new to me.
I gave up being young a long, long, time ago. I give respect where respect is due, but when the gray came to my hair, I stopped granting respect automatically.Welcome to SS, now respect your elders young man!
Glad to know that.Just kidding, well sorta.
Some of the folks replying to you are some of the best resources in this business.
Now how exactly would I know that? I don't have any 11x20's to measure, or compare the 9x20's to. At the point where I made the statement about researching the diameter, nobody had yet ponied up that information.I'm really surprised that you'd make an assumption that the 11.00x20's and the 9.00x20's are the same diameter. I (and most here) don't need to wait for you to measure, I've got over 125 of each mounted on running trucks and trailers. They are not even close!
And I'll take it as such... up to a point.Just some freindly ribbing Chuck.![]()
