CTIS and the Newbie
pbranch
AZ
I have acquired an M35A3. It came with two flat tires on the passenger side and a CTIS system whose controller I can't read but which obviously doesn't work. How do I trouble shoot the system? I have read enough to know that many will say disconnect the system, but I'ld like to try to see if it will work first. Can anyone help?
Scar59
42
Mt. Eden, KY
The flat tires are most likely bad/leaking wheel half O rings. Try to inflate and see if they leak down. Check all electrical connectors in the system and at the controller. The controller should light up the display if power is available. Google CM Automotive, the manufacture, trouble shooting guides are available. give them a call. Check the distribution module under the truck. Report back.
