CTIS banjo bolt seal
TomTime
1,672
MD.
Coach, I was having difficulty finding a bolt that is not drilled for plugging my spare tire CTIS. I suppose I could find a shoulder bolt, but the army uses a blank banjo bolt. I guess this may be a minor hijack but near to on topic.
The TM (9-2320-366-24P-1) for the M1083 shows a bolt for the CTIS spare tire on Fig. 207 (2 of 2) number 32.
Part #: B1821BH063F150N SCREW, CAP, HEXAGON H 5/8-18 X 1 1/2 (Spare Tire Only)
NSN: 5305-00-727-2283
Here is a website that has them but you have to buy a package of 20 @ $1.98 each.
Fastenal show a part number of, 9940224. The most right column of numbers, 10th up from the bottom.
I think this is what your look for...maybe/maybe not???
GeneralDisorder
6,078
Portland, OR
The CTIS valve on the spare tire uses a SOLID bolt and nut for storage to hold the seal washers and keep out dirt and debris. That is NOT the banjo bolt that is needed when installing on the truck for service.
ramdough
1,731
Austin, Texas
Is it a standard bolt or a slick banjo bolt that is not drilled.
87cr250r
2,126
Rodeo, Ca
A standard bolt will work.
87cr250r
2,126
Rodeo, Ca
If you're using a nut and bolt you're going to need to use a capped or acorn nut otherwise air can leak along the threads of the nut. A new nylock nut may also seal sufficiently well.
ramdough
1,731
Austin, Texas
I am just wanting to keep water and dust out of my spares. But, that would do a better job of sealing if the threads are in the sealing washer.
coachgeo
3,538
North of Cincy OH
shrink tube. Folk do that over electronic boards in RC cars etc. while hot pinch the end with tweasers or something to melt the end shut. With that in mind you might can heat up a PVC tube ... while hot.... screw it on to thread it. the PVC glue a pipe cap on that. or mayyybe; if you can find a way to hold a hot PVC part, head and thread a PVC cap onto it
something like this
