Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
Well, the buttons don't always work, and I thought that if I put a pressure gauge in the dash and a 3-position switch; it would be better. I'm not at all familiar with the wiring on these, but I'm learning.
It would be a little more complicated than that. You would have to devise a way of supplying 12 to 15 psi of air to deflate the tires to the next lower level. I would suggest another ECU with good buttons and leave it as it came. Probably cheaper and a lot less work.
Using the M929A2 Dump for construction. Need to remove all CTIS components and use visual sight in morning for operator to fill tires. Don't have mechanic to check CTIS system every morning. Need to get to work and go.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
