Ctis ecu grounding screw
Givinup
Oklahoma City
Oops. It was the end of the day and I was trying to complete my tear down for painting. I removed the ctis ecu from its mount, without noting the order for the washer, ground screw, ground wire, and ecu. Before putting it back together and running power again, can anyone around their truck please take a look and snap a picture or tell me the order? I won't be back up to the shop til Monday. If not, I imagine it's in the TM somewhere, but it'll save me 100 pages of thumbing through..
Sent from my SM-G955U using Tapatalk
TNriverjet
24
Clifton, TN
Are you just needing a photo of the white wire? I’m not quite sure what you need to see. Can I get a pic of what you need without removing anything?
Givinup
Oklahoma City
Yeah just a picture of the white wire to the screw. I usually take pictures of everything before taking it apart, so I don't screw up with the reassembly.
wheelspinner
1,518
North Carolina - FINALLY !
A photo of an assembled unit doesn't mean that one is right. If you are concerned about the order, the only way to be sure is to look in the TM. No one says who ever put the photo model together did that.
