CTIS leaking at wheel valve
ke5eua
41
Baton Rouge (Central), LA
CTIS started leaking at what I can only assume is a check valve at the wheel.
Attached is a picture of what is leaking. I've tried taking a screwdriver to it and no matter what direction I go with it, it doesn't stop.
Can I just remove this piece and block it off? Looking at the other 5 wheels two of them don't have this piece.
I did search but didn't see anything related to this part. Thanks in advance.
charlesmann
713
Temple, Tx
if you remove that, it will deflate your tire till you install a schrader valve in the stem. I did away with all my ctis stuff on my l/fmtv wheels. Several of my wheels had the pictured fitting, then the rest had a fitting with no adjustment thingy. You may just have a piece of trash preventing it from closing fully. Might not hurt, if you are gonna keep your ctis, to take it off and sock it in a mild detergent to loosen up the gunk inside, or simply bang it on something and hope the trash dislodges and it reseats for you.
