CTIS Parts
Hwhomes
Moses Lake WA
I really don't know. I damaged something on one wheel. It appears to be repaired but now the entire system isn't functioning. Where are the parts commercially available and are there diagrams or charts that allow you to cross reference?
Suprman
701
Stratford/Connecticut
Schrader valves are the common stem inserts on tire valves. What is or isn't working? Does your system do an initial pressure check after starting and the air reaches 120psi or so?
Hwhomes
Moses Lake WA
So each tire has two? One on the pressure valve and one in the stem coming out of the tire?
cant tell if the system self checks right now but it seems to. The highway light blinks for a few seconds than all the lights blink. I drained all four tires and none of them are airing up.
Suprman
701
One in the valve. All lights blinking is a fault. It won't do any filling like that. Does it flash hwy then do a quick pressure test and then flash all 5? If so you may have a leak which the system would sense upon initial pressure check and give the 5 flashing lights error.
steve6x6x6
37
Winter Haven, florida
I have a load of LMTV CTIS new parts. New drums and loaded back plates. I have so much of that stuff i have been filling my scrap trailer with it. All axle stuff.
Suprman
701
It's a quick pressure check. Not usually hub seals but anything is possible. It's usually a hose or o ring. The pneumatic valve is behind the passenger kick panel. You can use a compressor to feed air into the valve body output and then go around with windex to find the leak. Usually a bad hub seal won't be a full open leak the system will send air and it will howl like a dying siren. That's a whole lot of axles.
Suprman
701
That's a hard fault then. Bad controller, bad wiring, bad valve body in the passenger kick. Check all of the connections for corrosion.
tburk49760
10
spokane washington
Disconnect the power plug on the side of the controller in the cab. I reset mine this way twice so far. Seems to be fine for a month or so. Eventually it will fail completely.
