The CTIS quick disconnect valves on my 93 civ hummer leak, again, all of them to some extent. The internal o-rings wear out and the valves start leaking air, usually depending on their position.
Nothing like the sight of a hummer sitting on the pad in the morning with all 4 tires flat to the ground. It does make getting in the door a bit more convenient.
I know some owners disable the CTIS, but this is not what I am looking for. I actually like the system overall, just not the non-servicability of the quick release valves.
Can anyone give me some pointers on rebuilding the valves? Officially they are non-servicable, but I did have one fail years ago where the retaining clip had broken. Looked like if they could be disassembled without damage, a rebuild would just be a new retaining clip and o-rings. New valves are not cheap, and they will undoubtedly be leaking again in a few years.
Or, has anyone had any luck replacing the AM General part with something from some other application? Maybe a screw valve with a T in the line for a separate schrader valve?
