CUCV 1986 M1008 - In a Real Pickle - Bad Heads - Need Advice
Commander5993
I installed Viton return lines in my diesel VW pickup, and cut an inch section that I plugged with a small bolt and hose clamp to replace the rubber caps. Never had any issues so far. I got the lines from McMaster-carr, they were something like $3.75 a foot in the size I needed. Hopefully that’s helpful for you! Really liked reading your thread so far, it’s great to see all the successes you’ve had on this truck, despite the consistent issues… but constant work is what keeps us sharp.
I'm going to order some Viton tubing soon, had some other 1/8" fuel hose to use temporarily on the line that was leaking. McMaster is $6.60 ft + $10 shipping now. Duda Diesel has it for $3.58 ft but shipping is $18.... :roll:
Good idea on making the plugs, don't know why I couldn't think of that. Thanks for the tip.
Have done a whole bunch of work to the truck since january, have other threads about those "exploits". These fuel lines are about the last of the repairs and maintenance I need to get done... at least I hope it is. Can't afford to do more right now and I need the truck.
87cr250r
2,137
Rodeo, Ca
The fuel injectors likely have metric barbs on them but I promise the 1/8 tubing fits well. I have used the 1/8 for years and I don't use any clamps on the tubes. I suggest the McMaster route because you're guaranteed to get Viton tubing. You won't know what you're getting elsewhere.
Commander5993
well, thats true. about how many feet does it take for all of it? I know the one line going from the front injector to the hardline is longer. I was going to order 10ft just to have extra, but I think about 6 or 7ft would probably be enough.
87cr250r
2,137
Rodeo, Ca
I think 5 feet did it but I don't recall. I would also get the 1/4 inch hose out of the injection pump in Viton as well. Fuel is hot there too.
Make sure you get the thick walled tubing.
87cr250r
2,137
Rodeo, Ca
The SAE 30R9 and 30R10 are also acceptable for the IP return as they are high temp rated. 30R9 has a Viton liner and CPE jacket. I believe 30R10 is Viton in and out.
