I got my alternator through bolt today installed the driver side alternator on the passenger side wired up everything following the Roscommon 12 volt conversion and nothing. I have power to the gauges, GP relay but when I turn the key you can hear the starter relay click once but nothing to the starter. I remember this happening to me once before years ago but cant remember which wire wasn't connected to cause this problem.
Are your battery terminals clean and tight?
When you say one click then nothing, does everything lose power after the click?
If you turn the key to start several times, does it click each time?
I would start by measuring voltage at the small terminal on the starter solenoid itself while the key is being turned to start.
Make sure you have the solenoid under the dash clicking AND in turn the solenoid on the starter is clicking too.
After that It would have to be a problem inside the solenoid or with power to the starter winding via the BIG battery lead.
All your ground wires good between chassis and engine block, Negative terminal block and frame?
Basically, now that you are operating on 12 volts you can just jump the small terminal on the starter solenoid to the BIG terminal on the solenoid and it should engage and spin the starter.
Would have been a bad idea before since the solenoid was 12v and BIG terminal 24 v.
Now it is like any other 12 volt system.
