Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
Thanks,
was trying to put my 6.2 donot J code into the M1009 late this afternoon and having some issues getting the THM400 lined up. Noticed the front driver side oil pan looked a little tight at the cross emeber but I'm not lined up on motor mounts yet either.
Code C, Code J, all the same block. The small differences are inside! So the engine should fit into a M1009. The TM 400 in a M1009 is standard, so this also shoud fit. Connecting the flywheel with the torque converter needs some space, means to fit the bolts without the oil filter installed. It makes it easyer.
Wolf
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
