AZDeuce
- 38
- 28
- Tonopah, AZ
I screwed up. I forgot to draw a diagram of the inside of the ALT before I disassembled her. I figured I had run off a copy of the Delco-Remey manual I found on this site and was good to go as it had pictures.
But when I went to reassemble it I ran into a dilema, the picture doesn't match my ALT.
I'm sure that mines a military Alt as it has fiber cupped washers at all the ground points/assembly screws.
My problem is that there is a wire that runs across what looks like a condensor, I can't remember where to attach it!
DOH! (getting old sucks!)
Does anybody have a diagram of where this wire goes? Or at the least can tell me where it goes.
I can reattach it one of three ways, I'm pretty sure TWO of the must be wrong!
The easiest way it lines up is with two of the different "isolated ground screws" that hold the components to the case. I'm "pretty sure" thats wrng, as that would defeat the isolated ground I think.
Can anybody help me out?
Thanks!
Thanks!
