richingalveston
- 121
- 63
- galveston/Texas
I am putting this out there for any one to shoot holes in the idea. looking at the HMMWV parts, the crank and water pump pully are both 4 belt. The power steering is a three belt and alt a 2 belt.
I am planning to upgrade my 12volt alt on my cucv to a 200 amp. To do this I need second belt to that alt.
It appears this is possible if I change my pully's to the HMMVW pully's.
I will have to space my passenger alt out some in order to do this but that is the only bracket change needed. The passenger alt is mounted on the inside of the bracket and I may just have to move it to the outside of the existing bracket.
This would allow the inside belt to go to the power steering pump, the next two belts would go to power steering pump and the drivers alt. and the last belt would go to the passenger alt.
With a 200 amp 12Volt alt. The electrical system would now have a full 100 amps of 12 volt and a full 100 amps of 24 volt.
Let me know your thoughts on the idea. I am looking to do this so I can have 100 percent of my 24 volts dedicated to the Inverter I plan on installing to run my AC unit.
Thanks,
Rich
Thanks,
Rich
