CUCV crank NO START troubleshooting and questions
WWRD99
1,942
York Pa
I think that I may redo my work on it and utilize the fusible link and thankfully I still have it, you don’t think that that wire above will have a problem with the draw? Also what does this bracket for the starter look like because i definitely don’t remember having one and or seeing it on the truck anywhere under there. So Iam going to definitely make sure I find one because that is one thing I do not want to do is dig those out if they break.
If you already have the wire, I wouldn't worry about it. You could put the end of the stock wire on for the fusible link. All of mine are wired like the pic I posted. The starter bracket attaches to the end of an outer bolt for the case or an aluminum arm with a stud. There's 2 different brackets, depending on which starter you have. I replace the bolts to the block with arp ones. The bolt for the bracket into the block is an 8x1.50 x 1 inch...I use washers and see how far it'll go in then adjust so it won't bottom out. I use blue lock tight on it, too. You don't want it to come loose. As far as the starter pics you posted above, that's a dead horse. Online most everything is a china kick. I do like the used gm ones from a few guys online around 130 shipped home.
Sent from my SM-S906U using Tapatalk
Blastercanon1
31
13
Sunset, Utah
Would it be worth getting the gear reduction starter over the direct drive one? I am going to call Boyce and see about maybe exchanging the one I got for one with the gear reduction and maybe even a bracket to go with it but I am diffidently going to pick up those ARP Starter bolts. I will let you know what they say after I call them and see what my options are as far as a used one goes, again thank you for all your help and incite
Barrman
2,244
Giddings, Texas
GM went to the Korean built reduction drive starter around the time they came out with the 6.5 engine. It was cheaper to build and lighter. Good and Good from their point of view. The military supply chain had to switch over as well.
I actually like the old heavy straight US made Delco starter. They are easier by a little to take apart. If you have a good straight unit, get the bracket and worry about something else. If you have a good reduction drive, get the bracket and worry about something else.
My first few years of CUCV ownership had a failed straight starter, a failed straight starter solenoid (Import on line purchase), seeing other people in CUCV’s at parades have starters fail for parade start up, hearing stories of starters failing at drive thru windows and other things that made me paranoid. So, I found spare starters, bolts, brackets and a case to carry them around in all of my trucks. Along with the tools to swap them out anywhere I might be.
I ended up with 3 straight starters and 2 redux units on road vehicles. The last one I had to change, at home when it sounded bad was almost 4 years ago now. That was a redux. The last straight I had to change for any reason was over 12 years ago. They can and will be reliable once you get everything sorted with quality parts.
Blastercanon1
31
13
Sunset, Utah
I was able to exchange the starter for a different one and also get a bracket from Boyce and all I have to say is they were fantastic to deal with and went the extra mile and the guys down there are very personable and I even stuck around and chatted a bit with them before I left. The starter has been fixed and installed and so far runs great and it has been starting super easy and it has been very cold and windy out here in Utah the last few weeks and I am now more confident than ever in my M1008 , but I do like the idea of keeping a spare starter close by just in case. Now I can focus on cleaning up the edges around the truck and slowly getting her back to her former glory. I really appreciate all your guys incite and help with the problem I was having and I can rest easy every time I come to this forum because this is diffidently where the experts hang out.
WWRD99
1,942
York Pa
Good news all around then!
20,798
And even though it is cold outside, I would take a few minutes and crawl under the truck and check the torque on the starter bolts after about a week. Guessing that could be 14 or more starts a day... If they have loosened up you need to know it before it starts chewing up the flywheel.
