- 1,961
- 218
- 63
- Arizona
The vehicle is a 1986 M1028 that is mostly stock. I have done the Doghead mod and I have bypassed the resistor and taken 12v directly off the bus above the glow plug relay. I have AC60G glow plugs.
I recently was stranded by dead glow plugs. I got the truck home and began to work on it. Each glow plug had no continuity and I could not get a reading of the resistance through them. (OL on the multimeter)
Deciding those glow plugs were dead, I got some AC Delco AC60G glow plugs and some 1/4" spade connectors. I removed 4 of the old glow plugs without any problems. The remaining 4 were swollen and would not come out by hand. I borrowed the JJ And A Racing glow plug remover tool from a buddy and used it to remove the others. I squirted a bit of WD40
onto the thread area of the glow plug hole to lubricate it so the swollen glow plugs might come out easier. I didn't have to put a socket or wrench on the tool to get the swollen glow plugs out, they came out with finger strength. No bits of pieces seemed to be missing from any of the swollen glow plugs. Thinking maybe WD40 wasn't the best thing to use, I left the glow plug holes open overnight so maybe it would evaporate out. ![Oops! :oops: :oops:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The next day, I put the new glow plugs in, installed the new spade connectors and fired the truck up. It started great, but now has a tapping/knocking sound. I shut it off and started it again and it has the same noise. I feathered the throttle a bit and the noise followed the RPMs. I took the glow plugs out and they are undamaged. I disconnected the pink wire and cranked the truck for about 30 seconds to see if I could "blow out" anything. I put the plugs back in and started it again with the same tapping/knocking noise. I tried to listen to see if I could figure out where it is coming from, but I can't locate it specifically.
Did I detonate the WD40 in the pre-combustion chamber and bend a rod? Did I hurt an injector? What is my next step?
