cucvrus
- 10,502
- 113
- Jonestown Pennsylvania
I sent you a text yesterday figuring you would have something already done.Made this for the Convoy. Magnetic base. Holds a large Dunkin coffee with ease. Worked great on the transmission hump even thru the thick rubber mat I have inside. It can be moved from vehicle to vehicle and no drilling required.
I guess I missed that in my search.Found a link to pics of mine.
https://www.steelsoldiers.com/showt...up-holder&p=164118&highlight=Drink#post164118
I have plenty of that type. Handle and no handle.View attachment 711271I use the Yeti with the handle and hang it up on things in the plow truck. Works well. Modern vehicles do have nice cup holders. On the CUCV any adaption that works is approved for a cup holder. With an added magnetic base the Yeti will ride upside down.
Certainly. It started out as a 4" PVC coupling. I cut the bottom out of a piece of laminate flooring with a hole saw. The pilot bit left a nice drain hole. They were attached with 2 part epoxy. On the bottom I used a magnet from an old strobe light and epoxied it as well. Works great, fits a big gulp easily and even a can with a foam koozie.I guess I missed that in my search.
That will work!
Can you post build details?
I do not have the Dash Plate.Here's mine. Not sure if you have the dash plate but mine actually came out of the services like this. Toughest cup holders ever. They bent up some flat stock and just bolted it to the plate. I actually had another guy locally try to buy this off me for his cucv. It'd be cheap to make, just a little time. And with the center gap, even the big mugs fit with the handles facing out.
It works and it’s messy too!Brand new roll of duck tape. Sticks to the floor and perfect size for a can and many cups!
Will be making two of these.Made this for the Convoy. Magnetic base. Holds a large Dunkin coffee with ease. Worked great on the transmission hump even thru the thick rubber mat I have inside. It can be moved from vehicle to vehicle and no drilling required.
