cucv floormat
txmytx_catahoula
-3
Port Arthur, TX
LMC, Brothers etc.... any place that has mid 80's chevy parts. There have been some threads where they aren't a true custom fit in the sense that they just drop in. Some trimming is required.
combatmech
Carrollton, Texas
Most folks dont keep them or put them in...I could be wrong. Mine came with a full floormat kit installed, which I promtly removed.....unless you know for sure that the vehicle doesnt leak when it rains, It'll trap moisture and help the corrosion along. 2cents
wallew
the ORIGINAL pattern is unavailable - I've looked for more than six years
the new stuff IS molded, but not the best fit - you WILL have to trim it just to get it to fit and even then it may not lay down correctly
AND this should be done on a warm summer day - when you can lay that puppy out in the sun for a few hours to make it softer - helps putting it in place and trimming
IF you are going this route, make sure your cab is dry and has no rust , especially any through holes should be repaired
or as said, every time you get moisture on the floor you have a chance to make your problems worse
ralbelt
9
West Warwick, R.I.
I could not remember the name but Durabak seems like a good product also. I have a sample and it seems plyable even in the colder weather. I'll be doing my cab floor when time and weather permits.
