Jersey4x4
- 1
- 0
- Absecon, NJ
Ok, I have known about this glitch for awhile and just have not cared enough to post but here goes. If I ground the rivet holding the volt gauge n the dash(either side) the volt gauge will read battery voltage. Is this normal? The key does not have to be on or anything. I found this by accident when the gauge was touching the dash due to a insulating spacer falling out and every time I got in the truck the gauge would move. Now if I need to check battery voltage I just use a screw driver from the gear selector to the rivet and instant voltage reading. I have had other CUCVs before but never checked to see if they all were like this one (85 M100 Anyway, just a thought.
