cucv ignition
l1a1man
idaho
I have searched and cannot find an answer. My 86 M1009 has a bad ignition. When I turn the vehicle to off sometimes it keeps running. Until I can get this fixed how can I shut down my vehicle in the event it won't shut off by normal means, ie, the ignition
K9Vic
Fort Worth, TX
A search would have found this, but you have to know the key words and is easier to use Google to search.
Anyways....
So how did you shut it off when it did not turn off?
Did you remove the pink (may look red) wire on the top of the Injection Pump to shut off the engine?
Warthog
226
OKC, OK
The TM 9-2320-289-20 manual has a section just for this problem. Usually it is the ground wire next to the emergency brake.
Also your ignition switch may be bad or needs adjusting.
On a diesel, there is no "ignition" system. Just fuel and air. There is a fuel shutoff on top of the injector pump.
