CUCV-II Engine Popping Noise
Stonepicker1
110
Coconut Creek, Florida
Update....Changing out the lifters didn't work. Started it up early this morning with my fingers crossed. Still popping out the intake. Next step will be pulling the engine and removing the head to see what happen. :(
I have to be in PA on Friday morning so it looks like I will be taking my CUCV dually( slower and more fuel)
1,827
Phil, I have one and the glowplug adapter. I'll take it to work tomorrow at the port. Will call and let you know where I'm at if you want to slide down and get it! I've already dug it out and put it in the car.
Stonepicker1
110
Took some time to look at this today,
I put the compression tester that I got from Kenny on the #2 cylinder and it only went up to 260 ft lbs. The other cylinders are around 385 ft lbs.
Looks like I have to pull the engine and remove the head to see what happened.:-(
Warthog
248
OKC, OK
Hey Phil,
how are you removing the valve covers without bending the snot out of them? I tried remove the covers from my GEP engine and bent the edges.
Stonepicker1
110
Hey Phil,
You have to get a small 2x4 and lay it on the top side of the valve cover and hit it with a BIG hammer a few times. That will break the gasket loose.
