CUCV-II Road trip FL to CA 2,668 miles
Stonepicker1
99
Coconut Creek, Florida
I was still getting water in my fuel filter and the truck was still running ruff, so I went ahead and droped the fuel tank. It had about 1/2 cup of water total in the tank. I cleaned the sock on the fuel pick-up tube( not that bad, but was dirty ) Put everything back together, added fresh fuel, cleaned and flushed the main filter housing, new filter, bleed all air out of the fuel system and cleared all the codes.
Took for a test ride and the same codes keep coming up. Water must of gotten into the injector pump.
I have a new injector pump that I will install in the morning. I will also be looking at installing another Fuel/Water Seperator before the main filter. This should stop this form being such a pain in the a**.
Stonepicker1
99
Pain in the back side is right. Do you have the means to set your offset learn?
Yes, I hooked the laptop up(running Auto Enginuity) and did the offset learn and cleared the codes. A few times the truck died after the offset was done.
I was thinking of disconnecting and reconnect the battery just to see what would happen.
ryan77
56
Cary IL
I know how that is with the wife im in the same boat i got the m1009 apart and the m1028a2 apart both are money pits and shes getting pissed!!!!!:deadhorse:
Stonepicker1
99
Before I replace the injector pump I thought I would try to see if draining the inside of the pump and cleaning the OP would work. I removed the top cover and sucked all the fuel out and blow compressed air in the housing to remove what was left.
Putting it back together right now...started to rain so taking a break for now.
If this doesn't work....replacing the pump.
Stonepicker1
99
After working on the truck all day. It is fixed.
Replaced the injector pump and filter assy. Took it for a test drive and it now hauls a**.:D
No codes came up.:eek::eek::eek:
I now know that my fuel system from the tank to the injector pump is clean, clean, clean.
I'll be heading to CA Sunday night or early Monday morning.
ryan77
56
Cary IL
Glad to here it, my old truck with the 6.5 had the throttle stick wide open so i had to do a pump not as bad as your nightmare though!! Soon it will be a dream when your hauling your treat home!!!!:beer:
ryan77
56
Cary IL
Best thing i ever did to my truck was the new ip pump and the remote pmd made all the difference! Had to sell the truck due to the wonderful illinois winters and salt ate the thing away!!!!
1,814
Life will be good if I never have to touch another DS4 pump in my life. Have a safe trip Phil abd if you return via one of the northern routes, let me know.
1,814
Be safe out there on the road Phil. Keep us posted if you can, if not, txt me and I'll let everyone know.
TCUCV
Chocowinity, NC
just read your entire thread and you definitely have worked your tail off getting your truck on the road in such little time . . . hope your travels are safe. I'm looking forward to seeing the new ride
Dave Kay
31
Kingman AZ
Just got to Louisian. Stopping at rest area for a break.
Fuel is cheaper here §3.73 gal. Back home §3.95.
Sounds good! But I strongly caution that you fill up WAY BEFORE you get into California because gas stations along the interstate will bend you ever here--- BIG TIME!2cents
Good luck and Godspeed!:beer:
