CUCV Instrument Cluster Repair
3cavtanker
Colorado Springs, CO
I was under the impression that the CUCV uses the same interior lights and gage cluster as a similar year Civilian Chevy Truck. Wouldn't it be much simpler to check junkyards for some of those parts?
skuhler
Columbia, MO
I've got a couple places in my circuit path that have shorted out, I've repaired them with the same kit that you use to fix those electric defrosters on windows, but it's happened again in a different place. Do you know where to get that replacement circuit pad? I've considered going to the junkyards, where I got a replacement dash pad and stuff, but the electronics on the junkers with be 20+ years old also.
Warthog
240
OKC, OK
If you are willing to be a guinei pig and want to spend $80, the circuit board from LMC may be a replacement. Looking at the pictures in the catalog it appears it is the same. I just have never needed/wanted to spend the cash.
http://www.lmctruck.com/icatalog/csb/full.aspx?Page=118
item #38-8036
Hawkman or HillbillyWizard may have some used ones.
85CUCVtom
26
Lakewood, Ohio
If you are willing to be a guinei pig and want to spend $70, the circuit board from LMC may be a replacement. Looking at the pictures in the catalog it appears it is the same. I just have never needed/wanted to spend the cash.
I have the catalog in front of me, are you talking about the 38-8036? For models without guages?
Warthog
240
OKC, OK
Yes,I added the part number to my earlier post. The one DH posted is $10 cheaper. Looks like the aftermarket guys are helping us out finally.
1,187
LMC
Part # 38-8036 PRINTED CIRCUIT $79.95 Each
usmcpatriot
-80
Bumpass, VA
Ended up repairing the cluster with a piece of copper wire.
I had some small diameter wire and used a hammer to flatten it. After trimming it to size,I used a 25w soldering iron and tinned the two peices together.
To hold the "new" piece in place I used some superglue.
I also had to restore a couple of light sockets. I heated the plastic up with a heat gun and reformed the plasitc. Then I smoothed it with a file.
Sorry for the picture quality. It was late.
Can you take a picture of the whole CB to compare thxs
antennaclimber
1,055
State College, PA
Hopefully this will help you.
usmcpatriot
-80
Bumpass, VA
I meant where did you get the pretty looking circuit board thx
Oh, off your truck. I'm trying to get one, I got copper tape, glue and will try to mend one or two disconnects. Hillbilly has used boards but as a, CB, lens, I think the whole cluster for $425.00 somewhat steep for me but might have to....thxs
ALTOcal
San Diego, CA
Hello, I’m trying to replace the backing plate for the instrument panel…and no one seems to carry a backing plate WITHOUT gauges. We only have idiot lights for 4WD, Oil pressure warning, and Gen 1 and Gen 2 lights. I can find the PCB for “WITHOUT GAUGES” but not that green backing plate. Mine has tabs broken off, and maybe I should just accept it’s held in pretty well…but my shift indicator just isn’t going to work (the pivot/pulley point is snapped)
I purchase LMC part 38-8100…and it’s got 1 of the idiot lights but the other three are for gauges.
