M923driver
- 4
- 0
- Guntersville, AL
Has anyone seen LED tail lights for the Chevy CUCV's? I've looked on line and found only a kit to refit them and they wanted about $300 for it.
Don't buy red leds to go under a red lens. Always go with white, the lens will provide plenty of color.
Yes, I've done this, an your lights will be dimmer than normal if you use the same color led and lens. Standard brake bulbs are white with a red cover. There are yellow turn signal bulbs, but most of these are installed under a clear lens.Hmmm. I've been researching this, and I've read just the opposite!
Have you actually done this?
I know this is an older thread, but I had to comment.Don't buy red leds to go under a red lens. Always go with white, the lens will provide plenty of color.
LEDs are completely different than standard bulbs.
