I went to start my M1008 and the starter hung and would not stop. I clicked the key on and off, and it just kept going! Eventually I turned the key off and it actually stopped/killed the truck. There was a real nice smell afterwards that I attributed to the starter. I pulled both the negative leads on the batteries and replaced the starter (batter tested as bad at part store). As soon as I touched the negative terminal to the battery post, there were some sparks, and the truck started turning over as if trying to start (with no key in the ignition). I removed the terminal and stopped. I had my friend slowly charge the battery's overnight. (I confirmed they read 12.6 volts.)
The next day I replaced the ignition switch (on the column). I took the negative and positive leads and posts and cleaned them with a wire brush. I then hooked the starter back up then went to place the negative terminal to the 1st battery (not the terminal that runs to the adjacent batter) and it gave a click like it was trying to engage the starter. It did not turn over just click. I put the second negative terminal on and it sparked... within seconds smoke started appearing what I think is the Engine WRG Harness Block right next to the power steering/master brake cylinder. I disconnected the terminal and got a real pretty arc that blew off about 1/4 of the terminal post.
On the starter I took off/replaced, I did not see a purple wire. There was only one wire on the solenoid.
I pulled the wiring diagram off NY Tactical website (
http://www.ny-tactical.com/PDF-Files/StartingCircuit.pdf) so I can start tracing things now.
From looking at previous posts it looks like it may be the following:
1) there may be a purple wire that may be loose swinging around around the engine that is trapped some where? (The truck is new to me so I have no experience or history with it)
2) The starter relay is bad?
What else should I be looking at? Also in which manual would one look to diagnose this?
Your help would be sincerely appreciated!
K
