donalloy1
- 1
- 0
- Martinez Ca
I did "Diesel Tiny Tach" also. Have been very happy with it's functionality. Really easy to instal also! Just my .02Look into a tach called "Tiny tach" easy to install.
Do you have a link for those?I did "Diesel Tiny Tach" also. Have been very happy with it's functionality. Really easy to instal also! Just my .02![]()
I have a M1028 that I am delighted with. I would like to install a tach to keep an eye on engine RPM's.
How can this be done with the 6.2 engine? I heard one can be plugged in to the back of the alternator. What tach should I buy?
View attachment 529264View attachment 529265
I thought I would show it off.
Thanks,
Steve
The tachometer I recommended looks just like your link but only costs $50 and does not need the magnets to function. Just tap into the single brown wire on the driver side alternator. It's available on a well known auction site.Here's the tachometer that I'm buying next. This one will fit into a 2 inch gauge hole and it's very easy to install. The sensor kit features two glue magnets and a sensor that mounts to the front oil pan bolt. You won't need to do a fancy wiring job with this tachometer.
http://usdieselparts.com/i-13464519-universal-electronic-tachometer-r8503.html
http://usdieselparts.com/search.html?q=R8900&go=Search
The tach that taps into the brown wire is installed in the dashboard right where my master electrical cut off switch is, so the switch would have to be re-positioned.The tachometer I recommended looks just like your link but only costs $50 and does not need the magnets to function. Just tap into the single brown wire on the driver side alternator. It's available on a well known auction site.
Unless he is talking about the toggle headlight switch setup.Hmm, could someone have added a master electric cutoff switch? My trucks don't have that.
There are no other components required. Just tap into the Brown (tan) wire on the alternator. I think my thread has the proper micro switch toggle pattern stated. There is a small set screw that can do the fine tuning once you have the right range.Hey Goldneagle,
my m1009 has been converted to 12v and I only have the passenger side alternator. I haven't been out today to check it yet but I don't think that should matter. So all you did was connect a wire onto that far right terminal shown in the picture of your alternator and then run that directly into the back of you tachometer? I heard that there was other components needed which is why I was straying away from it. If that's all that you did then I'm going to do the same. If there's more to this or I misunderstood, please let me know.
Thanks Goldneagle,have same tach and hope to get installed this week,looks very easy,I hope I don't have to fine tune,that hole on side is very small.There are no other components required. Just tap into the Brown (tan) wire on the alternator. I think my thread has the proper micro switch toggle pattern stated. There is a small set screw that can do the fine tuning once you have the right range.
"It's so easy a caveman can do it"
I would leave it there,get a new radio block off plate and put tach there,theres room for two gauges in the block off plate.OK, I'm back.
Attached is a picture of my M1028 dashboard where the main power switch is located. I believe it is where the tach fits in the instrument hole. My M1028 is the only one I have ever seen, so I thought all of them had electric cut off switches there.
Where could the switch be moved so I can install the tach in its place?
