aspen2hhi
- 0
- 0
- waukegan, IL.
HI Yesterday I was cutting dass in my m1009 for radio install all the sudden starter started cranking and wires started smoking pulled the battery cables removed starter relay put cables back on no smoke did the doghead relay mod truck fired up everything worked except voltage gauge. all good. today went to install radio the metal case slid through and sparks from the top of relay went to start truck starter wont turn. I tried jumping the rad and purple wire with screw driver nothing got out electrical tester no light on either red or purple. is there a fuse or fuseable before the starter relay
help please
help please
