CUCV Rocker panel no welding install
earnie
seattle ,washington,usa
Looks good enough for me! Great pics and explaination. Thanks
I have been considering using the same materials to do a similar repair on my 2000 Silverado.
I have found that they make "slip on" panels, that are actually sized to go right on top of the old panel, and be glued on.
sounds good but i believe that you must cut out all the rot b4 continuing as it will rot from behind
82ABNMP
53
Winston Salem NC
I think you could use the slip on type but as stated above I cut out all the rusted metal and used a rust paint (POR 15) over what was left THEN cut the new rockers to go over what was left of the panel.
David
82ABNMP
53
Winston Salem NC
Panel Bond
This is good for any NON-Structural section of the body. And with these trucks having a full frame, I would not worry about using it in most anywhere on the body. But I am not a professional...:p
David
QuickSilver
Wyoming
Good info! I need to replace both my rocker panels also, and I have very limited welding skills wo this is really helpful.
mr.travo
Comfort, TX
I imagine that I would be good for kick panels as well right? My drivers side is pretty bad and the passenger is starting. I am having a hard time finding the panel though. I know you cut the panel to match your cut, not cutting to match the panel. With that being said, do I just use some flat stock? I need to see how it all lines up because the inner rockers are all rusted out as well as the floor pan sides.
Lastly- This is my daily driver. How long does it need to set up before I can prime and paint it? I am just wondering if I can knock this out in a weekend or 3 days. I don't want to be using the LPC's for a week LOL!
