jplace1011
- 489
- 63
- Santa Ana, CA
Hi Everyone! I have a 1985 CUCV M1009. I noticed that the roof needs some love.
The area above the back seat and towards the back window in particular. I’m fairly certain the roof in that area is made of fiberglass. Hairs of the fiberglass are a bit visible. Do you recommend any way to repair that area? I’m thinking of using a Bondo product, but I’m not sure which one since there are so many to choose from. Maybe I should sand the areas then apply a Bondo product, sand it again then primer it then paint it?
Also I noticed there are a few areas of rust and holes. I’m thinking I should grind the rust off and existing Bondo, then apply Bondo patches, then apply Bondo filler. Then sand it and primer it, finally paint it. I’m wondering should I spray oil based primer before I apply the patches or afterwards?
Thank you in advance a head of time. I appreciate any help. You guys here in this forum are tryout the best!
