Cucv rpm's at idle
leisman7
Burlington, washington
I HAVE AN M1010 DOES ANYONE KNOW WHAT THE RPM'S SHOULD BE SITTING AT DURING IDLE? My batterires are charging at 12.2 i think its due to a low Idle speed. Just had the alternator replaced so its not the alt. Any ideas?
motormayhem
Tucson, AZ
I have a tach on mine and it idles between 640-660 when warmed up and in gear. Idles around 750 +/- 10 rpm out of gear and 850 when it is cold.
sp00n
26
Huntsville, AL
Check all of your cable connections for corrosion, breaks, or just loose nuts. Also check your ground wire to the frame.
