CUCV starting problem
2deuce
188
portland, oregon
When parked on an incline with the nose up the truck starts runs maybe 10 seconds then dies. Then is very difficult to re-start. I don't seem to get this on the flat. Once it restarts it runs fine. While trying to re-start it I have checked the fuel filter bleeder and there is pressure there. Has anyone else encountered this symptom and found a fix?
Thanks
acmunro
Reynoldsville,PA
You are getting air in the system. Possibilities are cracked fuel filter base, or a loose clamp on a fuel line, or a rotten/cracked fuel line. I have seen trucks that almost wouldn't start unless the nose was down. On the level or nose up makes the fuel filter the high point in the system - lets air in.
jag7720
Kansas City, MO
it is an air leak somewhere in the system... I had this problem for a while.
Could be the OE fuel pump too... they are weak. i switched to an electric walbro FRB-5
