dtdoyle01
- 0
- 6
- Tucson, AZ
I'm using an older CF-28. It will only be used for programing radios. The lower rack is set up with a newer computer to serve as a DVR. The shelter is one big faraday cage, so I counldn't use WIFI even if I wanted to. The radio antennas will be mounted outside on a shorter mast for reception.
Oh what type of tough book are you going to use? I'm using the cf-30 with 3g network and has gps it's a great laptop!
