CUCV U joints
l1a1man
idaho
Have broken several u joints in my M1009 on the rear shaft where it goes into the Diff. Are they a diffrent size than standard civilian ones?
mikev
73
Culleoka, TN
Can you detail what or why they broke?
I haven't replaced mine (OEM ones with 53K miles) and wonder what breaks them besides no PMCS or hard off-roading...
KsM715
142
St George Ks
OK let me first say that I do not own a CUCV so I m not familiar with where the slip joint is (on the shaft or on the transfercase). When you break the u-joint, did your shaft come apart at the slip joint (if the SJ is on the shaft) if your shaft comes apart make sure when you reassemble it you get the u-joints in phase with each other (lined up) or you will keep tearing them up.
If this is already being taken care of, disreguard and carry on.
ODdave
40
lansing michigan
Subscribing because i would like to know how the joint failed.
if you are intent on keping the 10 bolt, you can get a rear drive shaft & pinion yoke from a chevy pickup w/ 9.5 14bolt, have the shaft cut down and bolt it all in. This will give you a 1350 joint which is a lil bigger than the 3R joint thats in it.......Just a thought.
