johnpdo
- 0
- 0
- Buckner, MO
OK, my first post... CUCV wipers only worked on low, with no high and no washer working. Read the other posts,and disconnected the capacitors, wiring straight into the wiper motor. Cleaned the contacts, and now the wipers work on low and high, BUT...the WASHER motor won't turn off. Unplugged all the wires, and the wiper motor works, but the washer still doesn't stop. It appears mechanically driven. I see where some are using a universal washer motor. Is there anyway to fix my problem, or do I just need to breakdown and put in a different motor for the washer. If I do that, exactly which wires do I need to use to wire to the washer so the switch on the turn signal works. Any help?![Crying :cry: :cry:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
