cummins 727 with ford np 208?
res0wc18
Everett, Wa
hey all having some trouble with the swap.
Heres the rundown
Donor truck is a 1990 cummins auto 4x4 727 np205.
Reciever of the transplant 1986 ford f350 4x4 460 c6 np208
My question is how can i make my np208 work on the back of the 727?
heres some info
wow guys check this out.
These guys say that with a half inch space i can bolt up my 208 case to the 727? they are the same pattern etc?Anways heres the link
http://powerwagonadvertiser.com/foru...ead.php?t=2600
and here is another 727 np 208 combo.
http://www.overlanddiesel.com/71/80.htm
steelsoldiers
4,089
Charleston, WV
I must have missed something. Where does the M880 come into the equation?
Why would want to use the NP208 over the NP205? The 208's are OK, but why test it with 400+ lb/ft from the Cummins. Stick with the robust cast iron case and steel gears. The only advantage of the 208 is the 2.6:1 low range vs. the 2:1 of the 205, but someone is making a low gear set for them now.
Give these guys a call: http://www.fordcummins.com/ They'll steer you right.
3,115
You can buy an adaptor housing to fit the Ford trans. IMHO, The Ford is better than the Chrysler. Let me see if I can dig up a Cummins p/n for it.
res0wc18
Everett, Wa
you all know the most about the 727's is why. Anyways the dodges are the wrong side drop of a transfer case is why otherwise i would use the 205 thats on there now.
So you all think i should use my c6 etc instead of the 727?
There are plenty of ways to adapt my c6 to the cummins. i just thought it would be cheaper/ easier/ better to use the setup that came with the dodge in the first place.
I know i can put a newer nv241 of a dodge auto to make it work but i was thinking that there has to be a way to make my 208 work or clock the 205 that came on it?
Elwenil
40
Covington, VA
Um, why not use a Dodge transfer case? The '94 and up Rams are driver's side drop and it would bolt up. I think the Ford transfer cases use a different spline. I also agree on using a NP205 if you can get one to work, or at least a NV241HD out of a newer Ram. I would leave the 727 right where it is. I do not in any way think a C6 is superior to a 727. If you look at the internals you can see why.
res0wc18
Everett, Wa
ive found a 241 locally that is going to be the cheapest and really the only route.
Hello i have a problem. i have a 1990 dodge cummins 4x4 auto(727). This drive train setup is going into a 1986 ford f350 4x4 that has a 460/c6/np208
Problem 1: Need a drivers side drop transfer case that will bolt up to the 727.First that comes to mind is nv241.
Problem 2: I want to use a np205 but the dodge and ford 205's are way different. So i though swap out the input shaft to the ford unit. well that would make the shaft way to long. and they use a wierd adapter. See where i am going with this?
Problem 3: speedometer issues. how would i make it work correctly when swapping out the cases?
here is the info site for all needs.
http://www.high-impact.net/transmiss...case_NP241.htm
http://www.high-impact.net/transmiss...case_NP205.htm
res0wc18
Everett, Wa
yes i did, and they agreed with me on the issues im having. Seems they mostly use the ford trannys, and their is no way unless you make a thick adapter or cut/respline the 205 to make it work.
So i picked up the nv241 today and it appears to be in good useable shape. First things are to get my drivetrain fitted and then start fabbing up my mounts etc.
res0wc18
Everett, Wa
im having my 727 rebuilt is there anything special i should have checked/ added?
Any products i should have installed/ rebuild kits to use?
Cummins Power!
