Cummins 8.3 M923 not building air
Thomas_G
Houston, TX
Have a Cummins 8.3 in a 923 that won’t build air normally. Replaced air dryer with a new one. No moisture in system. Do the air compressors go out frequently on these? The engine appears to be a reconditioned one
builds air air slow and hard to reach 80 psi
simp5782
Feo, Fuerte y Formal
9,268
Mason, TN
Different truck. That one was air dryer.
Take the discharge line off the back of the compressor and install an air hose and fitting with a gauge. And see what you have. If no pressure is there. You can try tapping on the unloader. Your gauge will wrap completely around. So it may not look like it has any pressure.
Jbulach
2,090
Sunman Indiana
You might want to put a tee and a $5 125-135ish psi pop off valve before that hose, you should be able to hear the pressure and volume before you have time to look at your guage, if you compressor is ok.
tobyS
816
IN
Here is my standard advise. Follow the control line from the top of the air compressor head to the unloader control valve. Take both ends of that line lose and blow air through it. Then take the control off, clean and re-lube it with tacky grease (red) that is waterproof on all surfaces that can corrode and rust, especially around the spring.
Find a really small funnel or injector and put Marvel Mystery Oil or a good pneumatic oil into the head. There is a control piston that gets seized up with water and crud that holds the intake valve open and it won't let it close. Put the tube back on and work oil into that line at the top. 50/50% chance it works to free it up, so worth a try.
Re the control cleaning---keep track of the number of turns that the spring takes to take it out and put it at the same place when re-assembling. I first reset mine to about 125# and had the dryer relieving a lot so set it back to about 118.
Russ Knight
1,051
Perry, FL
I thought my unloader valve was bad. Turned out the compressor head gasket was brittle and had cracked in multiple places allowing the air to escape. The compressor is a pain to remove too...
