Cummins Logo on 5 ton 8.3L engine. Never lose it again.
Tinstar
2,569
East of Edmond, Oklahoma
Rarely do I see a 8.3L engine with the Cummins Blue logo plate still attached.
Silicone still stuck where it was. Clearly it doesn't work.
If yours is still attached, it will eventually fall off.
Mine was gone too and I bought a correct NOS Cummins logo on eBay.
They are hard to find. They were 3 years ago anyway.
If you want to apply your logo permanently, this is what I did.
Take the logo plate and hold it up where it is supposed to go.
Take a scribe or something and trace the outline of it onto the paint.
Once complete, use a small scraper or something to remove all the paint down to bare metal, staying within the outline.
I used Loctite H8100 Structural Adhesive to permanently attach logo.
Its a two part adhesive that when mixed, gives you about a 15 minute working time.
When fully cured, it's as strong as the surrounding metal.
I mixed up a small amount and applied to back of logo.
Used some 3M painters tape to hold logo in place while the adhesive set.
15 minutes later remove tape.
Unless your using a hammer and chisel, the logo will not come off.
I did this 3 years ago and it's still exactly where I put it.
Hot or cold engine does not affect it (I'm sure if your truck burned to the ground it would come off then).
I did not buy the special applicator gun this adhesive 50mL cartridge goes into.
Just simply pushed equal amount of depth on the cartridge plungers for the amount of material desired onto a paper plate.
Then using a small piece of plastic, mixed the two together.
When mixed its a dark green in color. Perfect!
If you have the cartridge gun and also the mixing tip, this job will be even easier.
You will be amazed on how hard this stuff sets up.
Ive used this stuff on other things as well (S-280 Shelter) and am impressed with how strong it is.
So, if you want the logo to stay put, this stuff works.
snowtrac nome
142
western alaska
look at mechanics tool boxes you will see where they go. A lot of mechanics take gasket scraper and rob them to stick on their tool boxes. now that I think of it kind of reminds me of the old Cadillac hood ornament craze the gangsters had in the 90's
3,164
I would NEVER.........
3,164
That size came on all midrange engines, A's, B's, C's the little Onan L series. I can't tell you how many engines went to ReCon with them still attached...hundreds. When a ReCon engine came in, they had no badging except for a data tag. Later in life they all started coming with the silver/blue one in the 3rd pic, top of the box to the left of the beige plate. There were so many of the small ones that I made key rings out of them, re finished them and we gave them to customers. I think I still have one somewhere. People liked them. Kinda one off
3,164
Here's as tidbit, in the first pic, a big C, next to that, a small C and next to that a blue/silver badge that says 440 plus. That was a very short lived experiment by Cummins ReCon. small cam....the NHC in these green things...STC, (oil controlled injection), air to water aftercooling, making 440 hp. Yes it was piston cooled. It was a camshaft eating monster. I saw these put 360-380 hp to the ground, that is way more than the normal 80% of flywheel rated power to the ground. The issue was that the technology to effectively and efficiently make good usable power at RPM less that rated didn't exist yet and the thing made 300+ pounds of rail pressure. The RPM, 18-2100 for power, and the high rail pressure/stress on the cam killed these in 20-50k miles. I saw push tubes and cam followers out the side of the engines. IIRC we only sold 5 or 6 of these and all of them failed catastrophically within the warranty period.
