Cummins NHC250 Head removal question
Kingpepsi
Wallingford CT
So i decided to pull the head on my truck to see how bad the cyl looks. Its the number 3 cyl so the middle head needs to be taken off. I have hit a road block. I have the head loose and it will move around quite a bit but it seems as though something is holding it down. I cant seem to free the passenger side rear corner of the head. Drivers side comes right up but something is snagging. Any chance that you cant remove the middle head without pulling the first head? Everything is removed from the head including fuel connection tubes, intake, exhaust, rocker boxes, push tubes. The TM says pull straight up and no dice.
Kingpepsi
Wallingford CT
I'll make sure I take some pictures and Bob thats one **** of an idea haha only problem is i have a rogue rod and chunks of liner in the bottom of the motor. Could make for great fireworks though :)
swbradley1
Modertator
1,918
Dayton, OH
Pull the rod out and get rid of a few pieces, I'll bet she starts right up. Mine did. :)
Kingpepsi
Wallingford CT
Heres the pics! All i can say is That don't look right :cookoo:
The head is garbage, the liner is gone, the piston was in the bore sideways, the connecting rod is bent, and the block is cracked. What a sound it must have made!
Triple C
NAPOLEON MO
View attachment 413302View attachment 413303View attachment 413304View attachment 413305View attachment 413306
The head is garbage, the liner is gone, the piston was in the bore sideways, the connecting rod is bent, and the block is cracked. What a sound it must have made![/QUOTE
Cracked block. Are you trying to salvage the motor or just interested to see what happened. Did you buy it knowing the motor was shot?
Kingpepsi
Wallingford CT
I knew it was shot when i bought it. Curiosity got the best of me and I really needed to see what happened. I have another motor lined up and im just going to swap it.
swbradley1
Modertator
1,918
Dayton, OH
That is a pretty cool looking piston. Great desktop paperweight conversation starter.
