Cupholder Suggestions
heywood
goshen/alabama
Has anyone come up with a (invented) a good cupholder
for a Deuce ....I'm tired of spilling coffee and soda while trying to to steer and shift while juggling drinks..
Somebody has come up with something..
Lets hear some good ideas
HanksDeuce
242
Prairieville, LA
I actually fit a cup from most of the fast food establishments I frequent in the crack on the fold down seam of the passenger seat. Jam it down in there about halfway so it doesn't move. Since it takes some finagling to get the cup in there I just lean over and take a sip at stop lights. :D I don't even have to take off the lap belt. Wouldn't recommend it if you are taking a drive with your best bud, though. People might get the wrong idea about you...
oklacowboy
Tulsa OK
So search works after all?
Like any forum... only when you don't really need it.
Been there with my old 80s camaro... local cop stopped my in hs to figure out what i was doing. he couldnt stop laughing when i explained it.
wreckerman893
Possum Connoisseur
15,627
2,042
If you don't mind reaching down to the floor a big roll of duct tape will accomodate the "Mikey D Sweet Tea" sized styrofoam cup just fine.
I guess you could set it on the seat too but it might slide off depending on how sticky the side of the roll of tape is.
I had some of the plastic holders they sell at Advance Auto but with a full cup of tea they tend to get shakey.
Stan Leschert
90
North Vancouver, BC, Canada
The fold up holders aren't worth the powder to blow them to Iraq. Freightliner makes some good ones for an angled dash,
but for anything else, M series included, I use a chunk of plastic pipe, with an end cap on it.
(Just big enough to fit your cup. Foam will snug it up).
The more securely it's mounted to the dash, the less Coffee on the floor.
Don't ask me how I know. Don't ask my fleet guy either.
He is still miffed that it took me this long to find out!
1,177
Great thread title!
This is why search does not work well.
goldneagle
983
Slidell, LA
How about a fire extinguisher mount with one steel band attached? I am talking about the metal ones that come in the M939 trucks. It has a flat base the the extinguisher bottle sits on. You can always replace the existing band with a stainless steel 3" or 4" hose clamp.
cattlerepairman
3,335
NORTH (Canada)
I found that the 3" axle nut socket placed onto the tranny tunnel makes a good cup holder, if the ride is reasonably smooth. It is quite a heavy piece.
sigo
Lieutenant Colonel
400
Leavenworth, KS
Cheap, quick and removable.
They also suck. Too lightweight for big drinks.
Thats what I currently use. They do suck. Mine are cracked and barely holding on. i like the concept but the plastic is too flimsy. I've been searching for something like that made of aluminum or steel. No luck yet.
bikeman
501
Ft. Bragg, NC
one of my old HMMWVs (I lost the picture I think...) had some improvised ones. Someone took 2 32oz gatorade bottles and bolted them into the dash... they are cut off at the first major indent, looks like it provides a pretty decent cup holder.
KsM715
142
St George Ks
I was going to suggest the same thing. Also if you ride solo you can fold the bench down and set it up there, its the perfect height. Leave the roll on the trans tunnel and it will get nice and warm and the glue will run out of the tape and hold that roll pretty good.
wiggall
151
Lenore, Id.
I took a medium sized tin can cut the top out drilled a hole big enouth to slip over the heater knob, and a small hole on top of the large hole. I like it now to paint it OD!
Vintage iron
Falmouth Ma.
here are pictures of where I mounted my cup holder. I use one for my coffee and i put my phone in the other lots of times. I have put big fast
food drink cups in them no problem!
Boatcarpenter
17
Marlborough, NH
Made it out of a couple of Sched 40 fittings. Bolted metal U shaped piece on the back and it hangs in defroster slot.
Works very well.
BC
