Curious old M49 fuel truck
msgjd
4,133
upstate ny
There must be a reason they put the extra wide 10-ton mirrors on those tankers (?)
yes, the operator(s) wanted it to look cool !! :D ... and better visibility in tight spots for sure , although the small rectangular mirrors on the early deuce A1's & A2's were better than round lollipops , but yes we operators definitely preferred the west-coasters (except when the trees or overhead truss bridges got really tight! .. slapped mirrors with other trucks more than once )
msgjd
4,133
upstate ny
Thanks again for your great help and have a nice day
Paweł
you have done an incredible job on this model ! :love:
where did you find pictures of the dash of a M44-series deuce gasser as reference?
i don't recall any of them having a tachometer or that many tags, but i suppose it's possible
it happened at some point in their life .. although 5T and 10T gassers certainly have a tach
one thing i learned about 6x6 trucks in my 50 years of hands-on, slight variations within each
type no longer surprise me .. My M49A2C (former gasser) has a tachometer with gauge holes punched in a pattern i have never seen .. again, this was converted into a multifuel and lost its original speedo-only dash , but did it really? Has anyone else out there seen this layout? I have not seen any gauge located between the speedo and tach , let alone a row of four at the bottom
... as compared to the typical M44-series gas gauges below , note no tachometer
Paweł
388
Poland
Hello everybody!
@msgjd - you overestimate my knowledge on these babies! I've found a youtube video showing the dashboard with the necessary data placards, but I didn't pay close enough attention to the dials - I didn't know I have to watch the tachometer closely. So you say the operators of the gassers didn't need to watch the RPMs too closely?
@Jbulach - well I'd do that if I wasn't afraid that they are going to wreck it in transit! But, more seriously, those funky mods are actually what I'm after! I'll also write that I treasure every time one of my friends here points out the mistakes - especially in time to be fixed! - because this way I get to know things otherwise very hard to find out.
It took me so long to reply, because I was fighting with the mirrors. You see I bought this kit on discount, precisely because it was missing mirrors. So first I made this, patterned on the mirrors from the M54 kit:
But then I took a look at my reference photo and you pointed me in the right direction of M123 10 ton mirrors! So I took my soldering iron again and I cranked out another set. These were harder to do and if you look at them you’ll see I was struggling, partly because my Chinese soldering iron turned out to be sh!tty… Here’s what I got:
Fortunately after painting them, they don’t look so bad I hope:
So let’s see how fitting them is going to go…
Thanks again for your great help and have a nice day!
Paweł
msgjd
4,133
upstate ny
The only M-series 6x6 gassers with a tach were the 5-tons and 10-tons ..
I have never come across a M44-series 2-1/2T 6x6 gasser with a tachometer . None of the 1950's gas GMC's (M135, M211 etc) had a tach either .
These gas deuces were built during an era where drivers were expected to have an ear for RPM's and there is a tag on every M-series gas deuce dash telling a driver the maximum speed in any given gear , no tach needed . Some even have a tag that reads "Do Not Overspeed" , the driver is expected to monitor the speedometer and honor the max speed tag . The engines have governors as well
Tachs are handy on the larger trucks for operating special mounted equipment or monitoring the best shift points while doing the much-heavier work typical of the 5T's and 10T's.. The shift point RPM situation is especially true for the slow-falling RPM LeRoi V8 in the 10T's..
The Continental R6602 in the 5T's was a proven heavy commercial truck engine prior being used in the M-series and apparently is more sensitive to over-rev than the Reo OA331 and GMC 302 that's in the M-series gas deuces.. It's possibly another reason why they have a tach in addition to being able to monitor shift points when heavily loaded.. The R6602 engine decelerates a little slow, but is not as slow as the LeRoi engine
I wouldn't be shocked if somebody out there has a gas deuce with a tach or had seen one although i don't recall seeing a connection port for a tach cable on either gas deuce 331 or 302 engines
amazing work on your model !! (y)(y)(y)(y)(y)
Paweł
388
Poland
@msgjd - thanks a lot for your comment and for your kind words!
When I was learning to drive, and it was in the mid nineties, many cars still didn't have the tacho, so we were also required to listen to our engines, plus there were practically no cars with automatic transmissions. To this day almost all drivers in Europe are trained with manual transmissions. Luckily they are all synchronized, so no need for double clutching or stuff like that.
On newer cars (but not the newest) you get the signal for the tacho from the alternator - if you take the current from before the diodes and measure its frequency you get pretty good idea about the RPMs of the engine, plus you get a hint about worn out slip rings when your tacho starts freaking out. On the newest cars you get the RPM info from the engine control computer (eek!).
Those mirrors fought me some, but now they are finally done and lok like this:
Thanks for looking and have a nice day
Paweł
Paweł
388
Poland
Hello everybody!
And my baby is now finished.
I'd like to thank you all for your comments, but my special thanks go to @msgjd and @gringeltaube - without them and their great help with the necessary references I wouldn't be able to build my model right.
Here’s my reference photo again:
And you can judge yourselves if I got it right:
Thanks for looking and have a nice day!
Paweł
Paweł
388
Poland
Hello everybody!
Thanks a lot for your comments and for your kind words! I'm so glad you like my work.
Congratulations on completing it.
Thank you very much!
without having the real thing sitting close-by
Well, that's where you helped me a lot, thanks again!
But glad you rolled it over for us to see the underside
I like to have my models accurate from the underside, too - it's sometimes hard to see a truck, tank or a dozer from the underside, but you can easily flip the model around, or put it on a glass shelve - makes for a good educational tool.
it immediately hit my instinct to grab a rag and grease gun ! :LOL:
You're not a driver, you're an operator, eh? :) I'm so glad my model evokes the reactions I intended!
Thanks again and have a nice day
Paweł
