CV boot buckling on new shaft install! Just cosmetic or future problem?
Edis06
Florida
I ordered and installed new driveshafts from SECO about a month ago and installed. Thought it was easier and more reliable in the long-term than replacing my ripped boot. While there are no performance issues yet, the boots on each side of the diff are buckling. Haven't seen this before. Any thoughts? Is it strictly cosmetic? Should I worry?
TOBASH
3,397
Brooklyn, NY
I don't know the brand reputation but seems cosmetic.
I believe these form a "perfect seal". When you drive you make heat and maybe a bit of air escaped and now with the unit at ambient pressure there is a small amount of suction???
I would just drive the heck out of it.
Action
1,556
East Tennessee
your boot looks to only have 3 “ribs”. I think original have 5? It seems to be stretch fromclamp to clamp making it suck in.
Edis06
Florida
I was thinking the same. They fit well but here is some slight movement left to right. The originals were tight. The movement is slight - not measurable, but you can feel it if you test it with your hand.
Action
1,556
East Tennessee
IDK either. It was just their "10K halfshafts" which came with the boots already attached.
The only non-12k front shafts on SECO site (with the boot shown in your pic) may be the 7k shaft. They are in the parts manual listed for basic and A1 models. There is a different part number for the 10k (A2) shafts, which I dont see on SECO site. I know this doesn't help with the stretched boot question.
Edis06
Florida
Not sure then because I never order online - only by phone. They said they are aftermarket but they have had zero problems and zero returns. They are 10K for about $450 per set.
If they do fail, then I'll replace them with the AMG units. Hopefully this is just a cosmetic thing and won't affect performance or reliability.
