D-Max turbo on a multi-fuel?
5,144
Performance issues as I recall, two of them were threads here where people installed a 5t turbo with a wastegate.
If you're determined to force more boost down a 22:1 CR engine, that is your own prerogative. Just know there's a inherent risk in doing so.
JasonS
200
Eastern SD
I took off a wastegate to put back on a D turbo but that was because it was damaged. I eventually did obtain and install a good wastegate turbo. Who was the person who had performance issues?
Lonesome715
25
Columbus, GA
Thanks. I wil take the time to read that.
In other news. I sold the D-Max turbo. I got an offer I could not refuse. So now I am thinking the Garrett from the 97 PowerStroke I have would be a goos choice to use.
brianp454
12
Portland, OR
I think this is a neat idea, but likely easier to pop one of the 3 or 4 series turbos that were originally on these engines to experiment. JasonS has some good info in it. Maybe look into one of the versions that he did not try?
I find that my C turbo with the FDC bypassed does pretty good for general driveability. These trucks were not designed to blast out high HP for extended times as required for freeway speeds on grades. As a rule of thumb, smaller turbos spool up faster and give boost earlier and larger ones do the opposite. The variable turbo design was intended to span that gap. If you move to a "bigger" turbo you will likely loose out at lower RPM. It's all about trade-offs.
Lonesome715
25
Columbus, GA
Good points. I should have used the term better turbo than bigger one. I can see how a different series would be better than pulling one off a pickup truck.
HETvet
Bedford, texas
As for the VGT issues. Convert it to a vacuum unit. VW has been doing this for years. The turbo might not be a VGT turbo to begin with. The LB7 d-max is a nonVGT turbo. They started using VGT turbos on the LLY. The LLY turbo is good for 26psi and that's at the limit of its boost map. With an after market compressor wheel it can get safely to 32psi. Just some food for thought
