weisskr
- 0
- 0
- Dayton Ohio
I have Just breathed life into the latest genset and so far I have had to replace many things on it to get it up and running. One of the items was the injection pump and not sure if it is related to the problem.
Anyhow, I got it up running and makes power fine and the engine runs great! The engine makes a lot of smoke and smells of unburned fuel or at least I think it smells like fuel but it could be motor oil? I think it could be either a valve seal leaking by or a vale seat not sealing up. So I have decided to pull the head and send to the machine shop and have it hot tanked, valves grinded, valve seats grinded, new seals installed and have the head pressure tested.
The question I have is does anyone out there know if an injector or the pump would cause this condition? The only fear I have is the rings could be blowing by to cause the condition.
Any thoughts out there?
Kevin
Kevin
