kastein
- 26
- 18
- Southbridge MA
Yep... long as it isn't too high octane it'll work found a plate on my engine (LDS-465 multifuel) that reads "fuel spec - all petroleum distillates up to a maximum octane rating of 85m-95r" though I may have swapped the m/r or 85/95. Basically anything up to gasoline, just toss a couple quarts of motor oil or other heavy oil into the tank if you're running on the real thin/high octane stuff to keep the injection pump lubed properly, and try to stay down toward the heavy to mid end of the spectrum when possible i.e. don't run gasoline at all times. Avgas is right out, too high octane.
