Damage to 802 from non standard voltage/frequency
fa35jsf
32
OKC, OK
So I’m about to be stationed in Japan, and for those unfamiliar with their electric grid, they use 100V 50Hz power.
Now I consider myself above average when it comes to understanding electricity and electronics. I know that most modern electronics with wall wort transformers or built-in transformers can utilize a variety of voltages and frequencies.
However there are some things in my house that I am unsure of.
I was thinking of using my 802 and dial down the voltage and frequency to closely simulate Japans electricity. I would then plug different things into the generator one at a time and see how they work.
I understand the risk of smoke checking some of the things I plug in, but will I cause any damage to my generator?
Scoobyshep
1,032
Florida
Frequency is a function of rpm. So no harm there. Might be a higher current on the field windings but I wouldnt think it would harm it.
Sent from my SM-G973U using Tapatalk
Light in the Dark
5,470
MA
Most small appliances feature auto switching transformers, working anywhere from 100v/50hz up to 240v/60hz. Either way the hertz gauge wont go down to 50hz on an 802, so while you can do so by manual manipulation with the throttle cable and a kill a watt meter to confirm, I would not recommend it.
