Damaged PDP 1083
S&S EVT
Wichita Falls Tx
I have a M1083A1 with a damaged PDP. Do any of you know where I can have mine repaired or are there any available to buy? The number printed on mine is 12422367.
Ronmar
8,326
Port angeles wa
Green circuit board type power panel? look around your area for a Amature Radio club. I suspect your local county emergency management department is associated with an amature radio club or ARES(Amature Radeo Emergency Response) group. i suspect they will have a member or two who can repair the circuit board traces... Circuit board traces are not fantastic at carrying high electrical currents, that's why those panels must NEVER be over-fused...
GeneralDisorder
6,139
Portland, OR
Pictures? It's a pretty simple board. I replaced a diode in one recently with good success. The diagrams actually even had the diode part numbers so was no guessing of size or specs. Restored the starter button operation so I could delete the previous owners bypass wiring running up the steering column.
