richingalveston
- 121
- 63
- galveston/Texas
The Dana 60 I installed on my 1009 has some wheel wobble. This is not the death wobble while driving. I do not have a dial gauge to get accurate measurements but at the top of the 16 inch rim, the wheel will move in and out approx. 1/8 of an inch or a little more. With stock size tires it feels like a tire out of balance but when you put 37 inch tires it is much worse. The wobble is about 1/4 inch at the top of the tire.
Rims are good, does the same thing with 3 different rims.
The rotors drag slightly like they are warped but it appears they wobble the same as the tire.
Is it the Hubs or spindles. I think it is just hubs because spindles would only affect camber or caster and not make a wobble.
Could it be both?
I have all new bearings and it does the same thing in 4 or 2wd.
Any and all advise is accepted.
Thanks
Rich
Could it be both?
Thanks
Rich
