- 88
- 14
- 18
- Northern NJ
Can someone tell me what the story is on the two indicator lights on the instrument panel with the metal caps? I bought an indicator light from Saturn with red lense in hopes of connecting this to my convoy lights to remind me their on. I thought I would just take the metal cap off and put in this new light.
In looking under the dash there are a single wire (with metal tags #40 on each one - per the wiring chart this is instrument light circuit) going into what appears to be a light indicator body already there! The other end of the wires appear to go into the wiring harness. Anyone know what the other end connects to or purpose?
Also, the convoy light switch has four ports A & B are already populated with the wires to the power source and convoy lights. C&D are empty. I'm thinking of running a wire from the dash indicator light to either C or D to see if the indicator light lights up or splice into either A or B. Does this make sense?
Has anyone already been down this road and can share your solution?
