dash mounted flasher light
GoHot229
Have any of you members found a good looking and functioning light to use in conjunction with the flasher, mounted on a more "in your face" location so's that you dont just blither along with your flashers'a blinking for the last fiew blocks or miles? I have often enough made my turn and in low-stress, or should I say 'busy' conditions, down shifting or up shifting, manhandeling the steering wheel, checking the mirrors, looking over my sholder etc. and left my flasher just blazing away untill I happen to look down and notice it and feel like a big DUHHH....... I was thinking of mabe on the fold-down window frame about mid-heigth. I'v turned my turn signal unit (twisted) it clockwise on the column to have it more visable with the light at 12 o'clock position, but still its not sufficient sometimes to catch with my pariferal vison, thus the blink, blink, blinking along down the Highway. I really don't want to give the impression that MV's are just used by less than sharp operators. 'spose I could fall into that term now and again.
DieselBob
13
Arnold Maryland
I have been thinking about the same issues. With the small bulb in the turn signal switch, bright daytime light and paying attention to everything else it's easy to forget to cancel the signal. I am thinking about trying one of these.
Auto Meter Pro-Lite Pressure Loss Warning Light - JEGS
I had 2 of them in a pickup years ago, for oil pressure and temp, and they are very bright. With a little paint the metal body should look right at home in the deuce and it would be hard to miss that blinking.
1,127
Bjorn's buzzer idea is pretty much perfect.
Jones
Sacramento, California
The plastic instrument light covers came in different colors for other than vehicle apps.
I've seen them at Saturn Surplus in green, amber, blue and clear.
The earlier lights were a colored plastic cover with a metal cap crimped over it. When that cover was used as a high beam indicator, the little "bump" in the center of the metal cap was ground off to give a small dot of light.
Of course if all this fails, you could use a Model T spark coil wired into the turn signal circuit with the high tension lead attached to the driver's seat springs. I bet that would be even harder to ignore than the low air buzzer.
m109guy
27
ON
The buzzer idea is good, unless you are stuck waiting to turn at a light for a long time. Then I would think the buzzer would get really annoying really fast.
Jones
There are small solid state (piezo-electric) buzzers out there. Mallory Sonalert for one.
You have a large choice of sounds and sound levels.
One with a low tone that wouldn't be masked by the turbo whistle is what I'd shoot for.
They aren't as loud or annoying as a low air buzzer so you could probably tolerate one for a longer period of time.
Simplest install would be to just wire it into the same lead as the indicator light.
cranetruck
75
Meadows of Dan, Virginia
The sound is just right IMHO, used the flashers for hours on end during my cross country trip. With ear plugs and the engine roaring on long upgrades, the sound is at the right db level. In traffic, without ear plugs, it's good too, a sound fit for a deuce. If people outside can't see your signals, they can hear you. :)
