Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
I just did mine the other day to paint and trace a windshield leak. Basically just undo all the little bolts on the passenger side, including the radio brace (and don't forget the screw on the side of the dash pad). Then undo the screws that hold the dash panel on, pull the dash panel away, and pull up on the dash pad...real easy to do.
Glad you got 1 reply!
The dash is in by 10 screws and Im talking a M1008 so not much differance in a M1009 BLAZER.
Their are screws beside the driver door which I will call side of the truck.
You need to remove those screws also.
As for the front under the windshield its 4 little slide in things to hold down the dash.
Get the screws on the side of the dash after you have removed the 4 from the glove comparttment, and the other 4-6 screws then its just lift it up and pull back.
